Installation is not working
C-MOR Video Surveillance Support Requests
mavs
Post by mavs »
I have a problem instaling C-MOR on 1,5 TB VM disk.
I'm trying to install the latest version 3.712 on a 1,5 TB virtual disk under VirtualBox. I'm doing it on the same way I have installed smaller C-MOR VMs, but this time I'm getting the error message
Mountlist analyzed, 4 mb overallocated on/dev/sda
Has anybody an idea what is going wrong?
garry
Re: Installation is not working
Post by garry »
The automatic installation mode probably has an error in calculating the partition space. If you change the installation of C-MOR to interactive mode on the installation start screen and change the partition space for /dev/sda2 fix to 2048MB and the rest what ever is left it should be no longer a problem. The installation process shows right after setting the disk space if it was over allocated. Make sure this is set right and the installation should work.
Garry
Garry Fisher
