Good day,
I'm trying to change the IP address of my freshly installed Free C-MOR VM, but the C-MOR does not change the IP address. I verified a couple of times the settings and those are correct. I also switched off the firewall of my Windows 7, but it is not working. I use Virtualbox as described in the manual.
Any ideas what is wrong?
Thank you,
Castello
IPsetup Tool not working?
Re: IPsetup Tool not working?
Which version of VirtualBox are you using? It may be a bug in the Version 3.X. If you have the old version 3, you may upgrade to VirtualBox version 4 or you use a different PC/Server in the same network to use the IPsetup tool.
Garry
Garry
Garry Fisher
I had no issues with the VirtualBox yet. Do you really think this is the problem?
It worked using my little netbook changing the IP...
Hmmm......
Hmmm......
I used the IPconfig Tool, too. The changes did not appear to work, but it did.
I recommend runnning a ping -t command in a DOS box while using the IPconfig Tool. This may reduce the wait time
