IPsetup Tool not working?
C-MOR Video Surveillance can run on a Virtuall Machine (VM). Feedback and infos can be found here. This completely free Video Surveillance VM packages supports all features of C-MOR for one camera. It available for VMware, VirtualBox, KVM, HyperV etc. It can be upgraded to a full version to support up to 15 IP cams.
castello
Post by castello »
Good day,
I'm trying to change the IP address of my freshly installed Free C-MOR VM, but the C-MOR does not change the IP address. I verified a couple of times the settings and those are correct. I also switched off the firewall of my Windows 7, but it is not working. I use Virtualbox as described in the manual.
Any ideas what is wrong?
Thank you,
Castello
garry
Re: IPsetup Tool not working?
Post by garry »
Which version of VirtualBox are you using? It may be a bug in the Version 3.X. If you have the old version 3, you may upgrade to VirtualBox version 4 or you use a different PC/Server in the same network to use the IPsetup tool.
Garry
Garry Fisher
castello
Post by castello »
I had no issues with the VirtualBox yet. Do you really think this is the problem?
It worked using my little netbook changing the IP...
Hmmm......
peter82
Post by peter82 »
I used the IPconfig Tool, too. The changes did not appear to work, but it did.
I recommend runnning a ping -t command in a DOS box while using the IPconfig Tool. This may reduce the wait time :)
