The new changes are:
- New C-MOR Start Page with variable, big video streams. The stream size now automatically adjusts to the size of the browser window.
- New single-stream browser windows with variable, large single streams, depending on the size of the browser window.
- Second index page with fixed camera stream sizes increased from 240 pixels to 320 pixels standard width.
- Deactivation of Java streams wg. lack of support in current browsers.
- New warning when Java Script is disabled as it must be enabled for use.
- Support for SSD hard disks for new installations introduced, Swap use in system status page (existing C-MORs can be adjusted manually by our support via remote maintenance).
- Introduction of new hardware models based on SSD hard drives and larger HDD hard drives.
- Fixed One Tap Button appearance in Internet Explorer
- Correction Configuration parameters for timelapse recording, current recording was not played when restarting the recording.
- False active links to disable cameras disabled.
- New graphical background display, if cameras are deactivated due to the time tables in order to generally improve the surface visually.
- Several small code improvements.
