What affects recording quality?
General Questions and Answers about C-MOR Video Surveillance
lomex
Post by lomex »
Hello C-MOR Community,
I have some questions regarding the quality of recordings.
I use the free VM for testing. All works fine and I could integrate my IP cameras. Now i figured that sometimes the recordings are a little jumpy. But this is sometimes only. Mostly the recordings are great and very fluent.
What can cause this jumpy, only sometimes occurring recordings?
Is this a virtual server problem or a network problem?
Can it simply not happen on the appliance version?
Thank you,
Lomex
michaelr
Contact:
Re: What affects recording quality?
Post by michaelr »
Hi Lomex,
There are many different things and parameters which can affect the video quality:
- A in general to high frames per second rate can cause jumpy recordings
- Too low bandwidth in the network. This mostly occurs when nightly backups are running
- Not enough CPU performance from the server system in virtual environments
- General low budget switches cause bad video quality
Make sure the server on which a Video Surveillance VM runs has enough computer power free for the VM. Video Surveillance occupies in general high compute power and network bandwidth.
If a network bottle neck causes problem you typically can see this in the System Status page on the green line for incoming network traffic. If you see a flat line far under 100mbit/s on a 100mbit/s network then you know not enough data comes either through the network or the camera does not support such a high frame rate.
I hope this helps a little to find the problem!
Regards,
