I got a 4XEM 4X-PZ7111 PTZ camera.
How do I configure C-MOR that I could control the camera on my Iphone?
Marcel
Need support PTZ for 4XEM Camera
That should be pretty easy.
- Please log in to your C-MOR Video Surveillance System as user admin
- click on the System Administration and select the camera you want to set up in the "Adjust Cam Configuration" section
- Click on "Camera PTZ Configuration" and you are in the right menu to configure the PTZ setting for your camera
- Select the LevelOne WCS-2010 camera from the pre-defined camea menu. This camera PTZ commands should be the same as for the 4XEM webcam
- make sure the IP/port/user/password settings are correct
- save the settings and enable the PTZ function
Does it work?
Does it work?
Garry Fisher
