I have set up a timeserver in the Systemadministration. C-MOR did
accept the setting without any error output. Anyway, since I have
set up the timeserver the system time has changed to 1/1/1970 12am.
Is there something wrong with the setting or does C-MOR not support
the Network Time Protocol (NTP)?
Problems with Timeserver
Up to Version 2.49 the testing of the time values given by the
time server does not work correctly in all cases. So far we
could not figure out under which circumstances the error occur.
Anyway, with version 2.50 we will release an improved check
of the data transfered by the configured time server. The user
can decide if the data is correct and confirm the selected
time server after a visual check.
