Page 1 of 1
Problems with a new C-MOR9P+ in MJPEG Mode
Posted: Mon Jul 05, 2010 6:13 pm
by marcel
I got another C-MOR9. This new unit support direct MJPEG streaming. However, the cameras 7 and 8 do not work. 9 Is not in use yet. The cameras work in the Single Stream mode though. Also in MJPEG mode, but not in the overview or if I go to a camera page with the thumbnail video views. Since the Internet Explorer does not support MJPEG streaming I cannot compare.
Any Ideas to solve this problem?
Marcel
Posted: Mon Jul 05, 2010 6:21 pm
by garry
Hi Marcel,
This is a well known problem. You probably use a the Firefox Browser?
You can call an Internal Firefox Webpage, just type
about:config
in the URL field of your browser.
In the search field enter: network.http.max-persistent-connections-per-server
Double click on the line which apears and set the value to 10 (or 16 for C-MOR15). Reload the page and the streams in MJPEG mode should work.
Firefox only support 6 Streams in standard mode. With this setting you raise this setting.
Best regards,
