Good morning,
I would like to put into operation a reasonable monitoring software for i.A. for my company. C-Mor I installed in Virtual Box, Network settings work and I get web access.
Software Virtualbox run on Rhel Linux on an Epyc 3101.
But I have some Trouble to get a Cam to Work.
Here are the details:
The Network Settings I set to:
IP :192.168.0.230 ( Adress is Correkt and workly with Webinterface, and Synlogie surveillance Software ( I want to shut down the Synlogie Surveillance Software in my Company and go to C-Mor Software )
TCP - Ip Port : 80
User : root
pw : *******
If I click "check the IP and Port" all works and I get a green Output.
In The Configuration Cam Typ, I choose the correct Cam for "Axis P1357"
Protokoll, I testes http:// and rtsp://
manual path : /mjpg/video.mjpg
Maybe someone can help me, to find the correct Configuration ?
Thanks in advance,
greets
Setup Help an Axis P1357
Qosmiosafe
Re: Setup Help an Axis P1357
Status is okay now. Its work with choose an other Camera Model where are behind ( RTSP )
