Increasing Disk Space C-MOR Software
This forum contains information on updates and installation for C-MOR. This forum contains older documents only.
admin
Post by admin »
Please use the attached PDF to increase the hard disk of your C-MOR Virtual Server.
Please be very careful using this document. Make sure you are having a snapshot prior starting the disk space enlagement.
Documentation Increasing hard disk C-MOR video-surveillance
Re: Increasing Disk Space C-MOR Software
Please be aware of the new partition layout of C-MOR Version 5!
The data partition is /dev/sda4 on C-MOR V5 and no longer /dev/sda3.
Also, if you have a VMDK disk in a VirtualBox VM, the steps to increase the disk are:
C-MOR VM shutdown
VBoxManage clonehd "C-MOR Video Surveillance-disk001.vmdk" "C-MOR Video Surveillance-disk001.vdi" --format vdi
VBoxManage modifyhd "C-MOR Video Surveillance-disk001.vdi" --resize 51200
VBoxManage clonehd "C-MOR Video Surveillance-disk001.vdi" "C-MOR Video Surveillance-disk001.vmdkk" --format vmdk
Delete the file "C-MOR Video Surveillance-disk001.vdi"
